I got the trial version I had try to used my m audio xponent and when I pluged in can’t use the controller only the audio car any solution or that only happen with the trial version?
could you tell us which operating system you are working with at the moment.
Thank you in advance.
Cheers.
we are sorry to tell you but M-Audio stopped supporting there controllers after Mac OS 10.7.4, there is no suitable driver for Yosemite.
I am sorry that I could not solve your problem and I am sorry for any inconvenience caused.
could you tell us what is not working? Are you able to assign any commands to the keys?
Thank you in advance,
cheers.
Yosemite is the actual Os I am using to work it djay pro 2
Thanks lukas I am now trying to using traktor s4 mk1 and mk2 and the software show me the option to open midi input port to configure the controller manually when it is opened pressing play move fader, jogs and it doesn’t work djay pro 2 show nothing anyway to fix this???
