I’d like to suggest two UI improvements for djay that would make the workflow much more practical, especially during live mixing.
1. Make the Beat Jump section larger
The current Beat Jump section is too small and difficult to use quickly, especially when performing. The controls are packed into a relatively small area, which makes them harder to see and accurately hit.
The Beat Jump section should be something you can glance at and use immediately without having to carefully target small controls.
This is what i suggest:
2. Add a permanent Stem icon/control
I’d also like to see a permanent Stem icon available directly in the main deck UI.
Currently, accessing stem controls can require additional interaction or depending on the layout, switching views. For live mixing, stems are becoming an essential part of DJing, so having a dedicated, always-visible Stem icon would make the workflow much faster.
I suggest 2 options, either one will work for me personally.
The goal isn’t to add more clutter to the interface, these could be treated as dedicated, clearly identifiable sections of the deck UI rather than controls that feel secondary or hidden.
I think this would make Djay’s interface much more performance oriented while keeping the overall UI clean.
Please make this happen, thank you
