UPDATED! Convert cue points and 1st downbeat from Rekordbox, Traktor and Serato DJ to djay
sorry for “spamming” but I cant delete or edit the previous posts
djay Conversion Utility for MacOS
The djay Conversion Utility (DCU) will convert cue points and the first downbeat of a beatgrid set in Pioneer’s Rekordbox, Native Instrument’s Traktor or Serato DJ to Algoriddim’s djay. The utility will generate a file that can be used with all versions of the djay app (both pro and 2) the converted file can be used on both iOS and MacOS.
DCU scans the entire collection and converts all the cue points and the first downbeat of the track automatically for all tracks in the collection.
In conjunction with Pioneer’s Rekordbox the utility can be used without the need for additional software.
Serato DJ or Traktor users need Rekord Buddy 2 (or a rekordbox.xml file with valid cue points and beatgrids).
There is no user interface other then a dialog box when the utility can’t find the rekordbox.xml file in the expected location.
If djay pro for MacOS is installed, DCU can install the converted file in the proper location automatically.
Users can chose to create a playlist in iTunes holding all tracks that have cue points. This option is very convenient for users of djay on an iOS device. It will take the guess work out of track synchronization.
DCU works from MacOS 10.6.8 upto the latest version (64 bits) incl. MacOS Sierra.
DCU is only US$ 4.99 and can be bought at
https://sellfy.com/p/emUY/
Even more updated!
The djay Conversion Utility also exports hot cues, saved loops and beat markers from Native Instruments Traktor to Rekordbox.
In conjunction with Pioneer’s Rekordbox and Native Instrument’s Traktor the utility can be used without the need for additional software.
Serato DJ users require Rekord Buddy 2 (or a rekordbox.xml file with valid cue points and beatgrids).
Rekordbox users need to go through the RekordBox.xml file to import the tracks into Rekordbox
demonstration video at
https://www.youtube.com/watch?v=vPzHv…
