USB-Stick in OneLibrary
Hi!
I have a problem accessing my USB Stick on Djay. It is exFat, I can access it by clicking on it at the MacBook desktop, but in djay it shows “connect usb drive”.
Anyone got a clue on this?
Best regards
Björn
Can you re-format the USB drive with macOS Disk Utility?
Hi @InterCEptor, welcome to the Community! If reformatting per Michael’s suggestion above doesn’t work, can you please confirm if you are connecting it directly to your Mac or through a hub or adapter? Thanks.
Tried reformatting but does not work. Using the other USB Port did the Trick.
Glad you sorted it out. Thanks for the follow up @InterCEptor
