Can you use iPad’s speakers for sound output, app djay pro, controller mixon4? To be specific, I use an iPad pro12.9 inch. Thank you.
I have a Mixon 4 and If you don’t have speakers hooked to it I believe you can just use the Ipads speakers - Does it not work for you?
>>DjKingBee
Thanks for your reply, I’ve been looking for output settings all the time that never actually tried without plugging the output.
Interesting how it recognizes the output source (when it’s just analog sound) and automatically switches to iPad speakers.
I’ll try it and update as soon as I get home.
Tried but did not work. Issue is different with iPad Pro?!
