Hi I would like to know who else like me is using djay2 I phone version on I pad?
This is so much easier to use live as all the functions and knobs are much bigger.
I never understood why algoriddim made the section (with the equaliser, FX, loop)
So small on the iPad version !! What’s the point of having a bigger screen then.
I’ve been playing and to touring professionally for more than two years with my iPad only now using djay 2 Iphone version. Using the Griffin splitter cable until I found a decent very small controller. I now use the Reloop Mixtour controller which makes a good improvement to manipulate the equaliser function.
When you travel with just a back pack for months onwards this is the best comprise “space, weight, efficiency”.
Anybody else out there doing the same ??
