Hi , I’m thinking about getting an ipad with a view to using algoriddim . I’ve got a large number of vinyl records which hope to record on the ipad , will I be able to use these records on algoriddim , if so how ? As the description on the website only mentions a music library using itunes and spotify. Thanks …
djay 2 for iPad supports major audio formats like MP3, AAC, WAV, AIFF. So, just get the records on your computer and sync them to your iPad via iTunes. When we say “iTunes songs”, it doesn’t necessarily mean that you bought them in the iTunes Store, just that they’re in your iTunes library and you synced them to your iPad via iTunes.
