I purchased the fx pack now how do I use it while playing music? Great app by the way I have been using it for school parties. (I work for the doe)
Hi William,
Thanks for your support.
Open the tools by clicking on the small “EQ” icon above or below the tempo slider, then go to “FX”. If you tap on the effect name, a menu opens up where you can select a different one.
I was looking for this answer. Thank you!
