After updating to v1.4.3, I no longer see MY Spotify Playlist. Please help. Thanks! macOS Sierra 10.12.13
You can use the tab bar icons at the bottom below the track list to switch between playlists, browse, and charts:
Hope that helps!
Never mind. I figured it out.
How did you find it? I can only see the Browse options, not my normal playlists
someone help having same issues
