When scratching while video mixing, my jog wheel goes crazy, as if the jog wheel was vibrating. When I exit the video mixing mode, it goes back to normal.
Hey Eros Ayala,
first please tell us a bit more about your setup.
-which djay version are you using?
-what device are you using?
-which operating system version is running on your device?
Cheers,Lukas E.
Can you attach an exemplary video of the explained behaviour, that would be helpful for recreating the issue.
Thank you in advance.
I am using djay version 1.4.3
I am using the ddj sb2
and I’m running OSX El Capitan
