Vjay crashing problems
Vjay keeps crashing on my iPad Air running iOS 10.3.1
I’ve loaded some loops and they sometime glitch, stop and crashes the app.
Anyone else experiencing this? I use this app as a back drop video for my band.
Any help or suggestions???
Hey there,
can you tell us which viay version you are using? You can see the version at the end of the settings.
Cheers,Lukas E.
Hey there,
sorry for the delayed response. I forwarded your issue internally and we are doing our best in order to reproduce it.
In the meantime, have you tried to reinstall the application and see if the problem is persisting?
Cheers,Lukas E.
1.4.5
1.4.5
Serious lack of support here. I want to be refunded for this unusable app.
Yes I tried everything and it still crashes. App is unusable on my iPad
