Vocals are removed in headphones on Deck 2
  • Device model (e.g. 2020 iPad Air 4th Gen): MacBook Pro 2019, iPad Pro M1
  • Version of operating system (e.g. macOS 14.4.1): macOS 15.7.4
  • Version of djay (e.g. 5.1.2): 5.6.3
  • Hardware/controllers used (e.g. Reloop Mixon 8 Pro): GRV6
  • Hardware firmware version (e.g. 1.0.1): dont know
  • After 15 minutes of playing, deck 2 is removing vocals from the song in headphones. But only in headphones and only deck2. Happening on both devices, MB and iPad.
C) EXPECTED RESULTS:
  • Don’t know if the issue is only on my device or it’s a known issue.
D) ACTUAL RESULTS:
Hi @Gabriel_Boros, since this sounds repeatable, can you please capture and share a short screen recording of the issue to help clarify what’s happening? Thanks!
That’s the biggest problem. When I play it, all is good. The recording is good as well. This is only happening when listening to what I will be playing through headphones. Its wierd. :exploding_head:
It sounds like you might be using Crossfader FX or Neural Mix. A video will help me to determine if these are activated or not.
Yes, I’m using them.
Thanks for confirming @Gabriel_Boros. Please try to capture a video when you are experiencing this issue to help us troubleshoot things further.
Also, please update the GRV6 firmware and retest:
