Hi there …when I’m using my ipad with djay2 the volume jumps and gets louder if I adjust the gain slightly or any eq levels on my vestax spin controller …am I doing something wrong .?
Hi Steve,
Thanks for contacting us.
Is “Auto Gain” and “Reset EQ” turned on?
Turn them both off, the problem will be solved.
Yeah they are both on it’s happened a lot just a big jump in volume even with the slightest adjustment of the gain switch.
Really …will try it …cheers
