Volume on tracks 3 and 4 much higher with controller!
  • ipad pro M2 (ios 26) and macbook air m5 (26.5.1), latest djay version
  • Reloop Mixtour Pro + Midi Fighter Twister
  1. Despite trying to switch on and off autogain when I use my mixtour pro, when I load a song to track 3 or 4, the volume is always way higher than the main ones (2 and 3) and I have to manually decrease it by lowering the fader to 3/4 to match it which is very annoying and not precise. Any fix ?
Thanks !
ah ! it’s not auto gain… I just switched off : dissociate the controller gain from the screen one and now all volumes are the same.
Hi @gric, glad to hear you figured it out.
