Hello, is there a possibility to adjust the volume of the sample individualy ? And also to use them individually ? This was possible at the normal Djay
It doesnt seem to be available from the screen menu but its still there. You can get to it from midi map controls … Which controller you using?
From the screen in djay pro for mac you only have the one volume control … The central switch.
The function to adjust each sample volume independanly is available in the software but to do it you need a compatible controller … Or you may be able to assign to your current controller by changing the midi map.
What controller do you have and i may be able to help?
Sorry then Rob … I dont think you can do it
I mean in DJAY Pro off course
I don’t know exactly what you mean. I am using a Macbook pro…
This is what i mean. I can only control the volume with the central switch…
Sorry but i don’t use a controller. I connect my macbook directly to the mix panel by using the headphone jacket or usb. So i use the day software directly.
Ok, so that is a big different compare to the simple djay. I hope there will be an update soon …
