I do not understand the Cue button behavior on the Wego3, on my iDJ Pro, there is a separate button to set the Cue and then the Cue transport button.
On the Wego3 this seems to be the same button, sometimes when I press it, it will take me to the cue point that has been set, sometimes it will set the cue point in the point of the song that I press it.
This happens whether the song is playing or not, you never know which action it will take, take you to the point or change the position.
