Hi - I’m struggling to understand how CUE functions on the WeGO3 when using Djay2.
* * * To be clear, I’m refering to the CUE button next to PLAY/PAUSE, NOT the 4 Cue Point buttons * * *
What I would EXPECT to see is…
Load track
Find the point in the track where I would like to set this cue, say the first beat
Press the CUE button
Now, if I press it again it will play from that point until I let go of the button, where it will then jump back to that point. So as you see the pros doing on CDJs - CUE-CUE-CUE-CUE-CUE-PLAY.
What I ACTUALLY see is…
Load track
Track jumps back to start of the the whole track, not the first beat, just the start of the track
It doesn’t seem to matter whether the track is paused or playing, at the first beat, last beat, random point in the middle, as soon as I hit CUE it just jumps back to the start.
Is this right? I know Djay2 has a non ‘standard’ way of dealing with this where there is a ‘set cue’ and ‘cue’ button on their UI so wonder if it’s to do with that, ie. set the cue with the ‘set cue’ button on the UI then use the CUE button on the controller - surely not though?
Just in case it’s firmware related I’ve posted this on Pioneer’s forum too.
