Thanks for contacting us.
Please kindly provide more information so we can better assist you.
- Which device do you have - iPad, iPhone or Mac?
- Which iOS/OS X version is installed on your device?
- Which djay version are you using?
- Does this happen with all songs?
Device: Ipad air about 4 years old.
OS: problem has been on many OS back but right now I am running ios 10.3.2
Software: Algoridm djay 2 latest version as of 20th June 2017
Current behaviour
* if you during automix manually put the next song in the non-playing deck while in automix that song is sometimes replace right before starting
Desired behaviour
* if you during automix manually put the next song in the non-playing deck while in automix that song should be played next and not replaced.
Ipad air -
10.3.2 (but the bug has been for many upgrades) -
Latest as for 2017-06-12 but the bug has been for many upgrades -
No it only happens sometimes, but VERY annoying every time in a live situation when you prepared a track and just before it should starts the automix feature takes another track. You have no time to correct it… anyway it’s a really bad buggy behaviour.
