i want to change a song from 100bpm to 120bpm by changing the tempo, then recording it and sending it to iTunes, however when i enter in the value of ‘120’ it only goes as high as ‘111.11bpm’ and this has been a problem with other songs when i try and sync one song from 89bpm with the other song at 87bpm but instead it changes it to '78bpm. What the hell have you done, i hate this new update
our apologies for this. Could you tell us which song you tried to pitch down to 100 BPM?
Have you tried manually adjusting BPM via the Pitch Fader or Tapping the BPM?
Thank you in advance.
