Hola! No encuentro el Delay (mejor con efecto de congelación) en las opciones de FX. Alguna sugerencia? Gracias!
Susa
Hi @Susavei, Thanks for posting on our Community. =) Please note that for ease of use for our international base of users, posts on the Community will be translated to and answered in English. I hope it’s okay that we reply in English here.
Translation of your post:
Hello! I can’t find the Delay (better with a freeze effect) in the FX options. Any suggestion? Thank you!
So that we can better assist you, could you please share the following:
- What device are you currently using?
- Which OS version is running on your device?
- Which djay version are you using? (If you are using an iOS/ Android device, please open the djay settings and scroll down to determine the version number.)
Thanks in advance!
El El lun, 16 may 2022 a las 10:30, Emily via Algoriddim Community Forums <
no-reply@algoriddim.com> escribió:
Hi @Susavei,
I’m sorry but your message seems to have gotten cut off here. Could you please repost your message? Thanks!
