Where is the User Manual pdf Djay
If your are looking for the Vestax/Djay Algoriddim Spin (1), you can find the manual here: http://www.manualslib.com/manual/3999âŚ
djay contains an âin-appâ tutorial.
For the iPad or iPhone version:
(1) click on the small button located beneath the big red record button
(2) select âHelpâ, and then âTips and Tricksâ
For Mac: simply press â? while in djay.
You can also check our Support page for more helpful information:
http://help.algoriddim.com
DDJ-Ergo V is natively supported with djay 4 for Mac. No need to map the controller yourself.
Which djay version do you have?
Hi Thomas,
please see my reply above. djay has an in-app manual.
Do you have a Mac, iPad or iPhone?
Hi Gregory, which app do you have exactly?
Hi Pete, pressing that key combination in djay should open up djayâs manual. Is this not the case?
By the way, once the help article is open, select âdjay Tourâ on the right.
the âin-appâ tutorial seems to be broken. try it out! clicking on âoverviewâ produces an error page saying there is nothing to this topic available
I am looking for a help/description of the âsettingsâ section of djay. a pdf would be most helpful! thanks a lot!
in the general settings âbei sync automatisch abspielenâ I donât see difference on or offâŚ
only âin-appâ. a pdf would be very useful since the in-app help seems to be broken
Where is the User Manual pdf for Djay (ddj ergo v mac book pro)
command ? while in djay did not show a manual
Can i get some support today
Midi mapping for jogwheels (Mac Book Pro DDJ ergo} Can i get some support today
djay 4 I want to adjust the Jog Wheel Tension
Where is the User Manual pdf for Djay (ddj ergo v mac book pro (OSX 10.8.2)
no manualâŚno buyâŚand command doesnt work on macâŚi cant work out how to turn off sound on mac while onair
The manual in app doesnât work
It is totally stupid to have no manual whats wrong here?
