Why is BPM auto adjusting from one deck to another?
I use Djay app to simple have playlists playing at events. I DO NOT need or want this adjust beats / beatmatching / sync or whatever you call it.
All I need is crossfades.
Last weekend at a wedding after the app must have updated itself it started to try to adjust BPM from one deck to another. It was very embarrassing and annoying.
How do I disable this feature please? Sync mode is set to OFF.
I never switched this function on myself.
  • Device model: 9th Gen iPad
  • Version of operating system: iOS 18.4.1
  • Version of djay
  • Where do I find this in the app? Maybe 5.3.1??
  • Hardware/controllers used: Non
Hi @coffee_king, in your Automix Settings, please set the Tempo Adjust to Off
In the CFX menu, please also disable Tempo Blend.
I hope that helps!
Hi
I can’t even find “Automix Settings” screen.
Can you advise where it is please?
Please see below @coffee_king
That’s got it. Many thanks.
Perfect! You’re welcome @coffee_king. Happy to help!
