Is anyone going to look into why the search bar disappears when the iPad is connected to Idj pro. While using djay2. Distorted sound coming from the hardware sometime even not playing.
we are aware of the disappearing search bar and it will be fixed very soon, thank you for the information!
To your distorted sound issue, could you please contact the support via support@algoriddim.com and tell them which device and iOS you are using right now, that would be great in order to help you.
We are sorry for the inconvenience and do our best to solve this as fast as possible.
Keep it up,
