Working for years as an open format DJ with rekordbox and my fabulous Pioneer DDJ-XP2 and now switching to Djay i feel very frustrated with Djay’s limited Tempo - / + in Midi Configuration.
I see no way to change that in Djay’s Midi configuration. (See screenshot).
Hitting the assigned Tempo - / + pad’s on my Pioneer DDJ-XP2 in Djay results only in 0.1% tempo increase / decrease which makes me 10 times hitting the pad before reaching 1.0%.
This corresponds to rekordbox’s “SMALL” setting which is way too small for me. I’ve set in on “MEDIUM” which results in 0,5% increase / decrease (see screenshots) and perfect for me.
Please give me / us the “MEDIUM” option too as in rekordbox since i’m using this all the time as an open format DJ!
Thanks for the suggestion @djbo. I’ll share this with our devs for consideration. In the meantime, please use the blue Vote button at the top left of this page so we can gauge user demand for this feature. Thanks!
Hi @djbo, a quick workaround would be to duplicate the MIDI mapping command a couple of times. This would result in the same command being sent multiple times with a single button press which should get you closer to what you want.
Hi Slak_Jaw, sorry, somebody close to me passed away which prevented me from concentrating. I’m back on track now.
Your quick workaround sounded exciting, but also puzzled me because i didn’t know what you meant by “duplicate the MIDI mapping command a couple of times” but i figured it out and it’s genius, exactly what i want!
For those who are searching for the same fix, see two screenshots.
Duplicating the MIDI mapping command six times is what did it for me!
You’re welcome @djbo. Glad to hear that workaround was effective for you - I guess I could have explained it more clearly. Thank you for sharing those screenshots. Also, very sorry to hear about your loss.
