Xone PX5 w/ Xone K3 Issues
  • Device model (e.g. 2020 iPad Air 4th Gen): Macbook Pro M3
  • Version of operating system (e.g. macOS 14.4.1): Current
  • Version of djay (e.g. 5.1.2): Current
  • Hardware/controllers used (e.g. Reloop Mixon 8 Pro): Xone K3
  • Hardware firmware version (e.g. 1.0.1): unk
I am using a Xone PX5 mixer, attached to my laptop via USB. All is working fine with audio and Djay Pro.
The Xone K3 is receiving power from the PX5 via the XLINK RJ45 link (it goes through the colorful power up sequence, then goes to the dim gray color), but it is not being recognized by Djay Pro and the “program” is not being sent to the controller to use as it does when I attach the K3 directly to the laptop via USBC. Additonally, when hooked via XLINK the XONE Controller Editor app can not “see” the K3 either.
If I disconnect the RJ45 XLINK cable, and connect via USBC to the laptop, the K3 works as expected.
Am I missing something?
Hi @BrianR, thanks for the detailed info.
You’re not missing anything, this is expected. When the K3 is connected over X:LINK, it doesn’t show up as its own USB device. Its MIDI is passed through the PX5’s USB connection instead, so djay only sees the PX5 and can’t load the built-in K3 mapping. That’s also why the Xone Controller Editor can’t find it.
For plug-and-play support, connect the K3 directly to your Mac with USB-C. A USB hub works too if you’re short on ports. X:LINK is a proprietary Allen & Heath feature, so we can’t support the K3 over that connection. I hope that helps!
Well, that’s interesting and quite disappointing. I was excited about only having the one USB cable heading to the computer from the mixer. If you can’t program K3 using the Xone Controller Editor through the PX5 (or a similar mixer), I’m struggling to see what the actual use case is for XLINK.
If I buy a 2nd K3 to use with DJay Pro as well, can I daisy-chain them via XLINK, or will I need another USB-C cable to the computer for that use case?
XLINK is not supported in djay - it’s a proprietary Allen & Heath feature. If you get a 2nd K3, it must be connected via USB.
