When scrolling through “supported controllers”, the m-audio xsession, shows up as one that is supported, yet when plugged into my ipad, it isnt recognised on both djay 2 and dj pro. Is it supported or not? If not, you might want to update your website.
Hi Suga,
the M Audio Session is listed as a djay Pro for the Mac supported Controller, not for a iOS version.
