The song info used to be normal. Song, artist, time, genre. Now the same info is listed 5 times all in the same line. After several shots of booze that usually happens but I’m wondering how the hell that happened and how to remedy it. I’m guessing I have to delete the program and get another one and try again. Anybody run into that? I have DJay Pro and that ones cool.
Hey there,
thank you for your post.
Can you contact us via support@algoriddim.com for further help?
Hey Richie Tunes,
we will look into your mail.
Cheers,Lukas E.
For all future users which are getting duplicated Song informations in djay 4:
Please contact us via support@algoriddim.com.
Cheers,Lukas E.
Lukas- I have same prob. Mine dups 2x. I run Djay 4 on MAC Book Pro with iTunes. Have you received any response??
