iPad - I just updated my iOS, and now the WeGo4 jogs aren't working correctly.
I use iPad plus Pioneer WeGo4.
Usually, while playing a track, I can search through it by spinning the jog wheel.
Today, after my iOS update (not sure if that’s the cause), while a track is playing, spinning the jog wheel does the “pitch bend” instead of searching through the track.
Major problem! How the heck can I fix this???
Press shift+ jogwheel and it will do the search you talking about
