Does pre-cuing also work via the controller (headphones attached to the controller)?
Im thinking of buying SB3…
I do believe the SB2 appears on the list of supported controllers for Windows. I am also thinking of buying an SB2 based on this.
@Hakan SB3 is not yet officially supported. I received an answer that they are looking into it
I bought the SB2 and it works perfectly! Midi mapping works like a charm. Plug and play.
On the SB2 it works.
