I have mapped most of my buttons on my Behringer CMD Studio a2 - it works fine.
Now I would like to map when I push two buttons at the same time on my midi-controller. Ive seen this in other DJ softwares.
Is it possible in Djay Pro for Windows?
I’m not so sure if you have “shift” button on your controller.
And I think you can’t force any buttons to be used as shift, if it isn’t already defined by manufacturer.
Any button and button combination is send as a midi command.
You need to figure out what midi messages your controller is sending and then you can map those ones.
I have pioneer ddj-sx2, and it can send a lot of commands, but the djpro2 doesn’t have enough functions which I could trigger …
