Midi Mapping on iPad Pro
I’m trying to override some of the midi settings for my mixtour to use with djay pro on the iPad Pro.
I’ve created a mapping file using djay on the map but am having problems transferring the files onto the iPad.
This is supposed to say I created a mapping file on the Mac not map.
Hi, Thanks that’s a great help, I was using an older version as I didn’t fancy paying by month for the subscription. But got it working now.
Cheers.
You can also now adjust the midi mapping on the iPad itself in the preferences… maybe that helps.
