MIDI Mapping Pioneer DJM-900 NXS 2 To DJAY PRO
Hi there
any one of you, use 900NXS 2 with DJAY PRO? If so, would you be so kind to share which knobs, buttons are mappable on PDJM900NXS2 with Djay Pro, please? I couldn’t found nothing about that on Algoriddim site.
Thanks, appreciate that
Algorridim won’t have information, as it’s a Pioneer product. Google results tell me almost everything is mappable, but what would you want to map?
It’s an external hardware mixer, so you would set DJay to external mode and send outputs from each deck to a mixer channel and mix with the hardware.
Actually I use X96 as external mixer with iPad, by the way, JFYI Algoriddim should has information about as their app Djay Pro how mappable to their supported mixers as one of 900NXS! PK, what google result you’ve got, can you share it?
None of you use 900NXS?
I think most people are using DJay with a controller, or if they use an external mixer then they are not mapping anything (because it’s not a controller).
