Neural mix EQ don't kill bass anymore
Before i was using djay Pro 5.0.2 and when i killed my Neural Mix Drums EQ i was also killing the bass but i updated to 5.1.3 and now i can’t properly isolate the acapella of my track when i create live mashup. How to get my old Drums and Bass Neural mix EQ again ??
  • Device model (MacBook Air):
  • Version of operating system (macOS 11.1):
  • Version of djay (5.1.3):
  • Hardware/controllers used (FLX6):
Your question:
Hi @Joshssn, are your EQs in djay set to Normal or Neural Mix? If you could share some screenshots to help illustrate the issue, that would be great. Thanks!
It was set to Neural Mix and I found the solution. In fact I selected 4 channels eq on the neural mix and when I killed the drums and the harmonics, the bass wasn’t killed but I switched back to 3 channels (voice, harmonics and drums) but nothing changed. I restarted the app after setting it up to 3 channels and all went good again.
Okay great. Thanks for the follow up!
