TIDAL not analyzing multiple tracks at once
Device model: iPad Pro (12.9 inch) (5th generation)
Version of operating system: 17.3.1
Version of djay: 5.1.3
TIDAL recently hasn’t been analyzing multiple tracks at once which makes it significantly slower to analyze playlists. I’ve seen someone else just post about this in another topic. I seen nobody else made a topic on this issue so I may as well post it since it’s been occuring for the past few weeks or so. Seems to be working normal for SoundCloud and local files.
The multiple track analysis caused huge problems with Apple Music. That’s why it has been changed to a track by track analysis which also concerns Tidal unfortunately. It looks like Algoriddim didn’t find a better solution yet
Simple trick of mine:
  • create a playlist
  • run it as automix for 20-60s depending on your network speed
Let it run when you are sleeping and on the morning all done :slight_smile:
Hi @DJ_Norm, as @Andreas_Haase1 already stated, this is not a bug. Multi track analysis was removed to improve stability.
