I use a DDJ-SB2 with Algoriddim. It’s mostly really seamless, however two issues are really annoying.
First, the tempo slider is incredibly sensitive, and I have to painstakingly move the slider the tiniest bit to get the tempo of a cued some to match the one currently playing. I couldn’t figure out how to reduce the slider sensitivity - is this possible? It’s horribly frustrating, especially when the slider refuses to jump .1 BPM and skips over the correct tempo.
Second, I can’t figure out how to map the roll feature. In Serato it’s a simple matter of hitting the slip button and activating the roll pads, but in Algoriddim it doesn’t work. What gives?
Thanks in advance for any feedback.
