Hello
I work with Djay 4.2.3 and I do not want to go to DJay Pro, which I find much less pleasant to use.
I encounter the following problem:
The software loads an old iTunes database and I can not seem to get the last one.
The latest changes or playlists made in iTunes are not taken into account in Djay.
Can not find info.
Thank you for your help.
Hey Chajmi26,
can you please contact us via support@algoriddim.com? Thank you in advance.
Hello
I just solve a problem several years old, which can be useful to others.
Encountered problem :
With Djay 4.2.3: The software loads an old iTunes database and I can not seem to have the latest, with new songs or newly created playlists.
The latest changes in iTunes are not taken into account in Djay.
Solution:
ITunes -> preferences -> advanced
Check the “Share my iTunes xml library with other applications” check box.
Then, press the refresh button of the library in djay.
It’s not harder, but you had to know.
