I’m a longtime user of djay/djay2 enjoying it a lot and it has definately taken my mixing to new levels. It’s a good tool!
The last days I’ve been playing around with the latest version of DJ Player on my Reloop Beatpad.
Some things strikes me as very good, or better (i won’t mention the areas where djay2 still “wins”, like the buy-in-app effects for example)
For example:
* the library gives place to all of the title by using two lines instead of one as djay2 and you can sort on comments (comments are displayed).
This makes it possible to actually see which remix it is… something that is, of course essential for a dj, how can you not know what track you are going to play?
* when the track is playing you can also see all of the artist/title
* The current effect in use is displayed without having to open an extra window
* The loop size is displayed withot having to open an extra window so you can easy and fast see the current size and change it
* the recorded set is exported together with a textfile containing all the tracks and their position in the mix, a very good, and timesaving idea! Unfortunately it doesn’t come with bpm and key, but i’m sure it would be easy to add
* The sensitivity of the gain works exact, like as if i can feel that i’m in perfect control of every tiny little adjustment,
* Accurate sound level meters helps, showing red when distorsion occurs.
Eventhough they are super-sensitive i think i can master setting the “so essential for a great mix” levels with some training eventhough i am not using the autogain.
In djay2 on the reloop beatpad i sometimes feel that the gain control is not reacting fast enough and it’s not precise.
It’s difficult to explain, I’ve said it before on various forums… but no response and no comments anywhere yet. I could be wrong, but i definately felt a difference when playing with dj player
There still seem to be some problems with the mapping of the looping of dj player on the reloop beatpad, but thats probably a bug (i think?)
I’d say that for now it’s equal to, or even beats the djay2 on reloop beatpad, and i’m going to give it some spins with real sets.
I’m a paying and happy customer of djay2 i should add.
