2026 STEMs Quality Comparison - DJcityTV (Mojaxx)
Mojaxx has done an update to his STEMs quality comparison video from 2022. I like how he’s put this together with the waveforms visible for comparison.
Obviously this is very subjective and Mojaxx doesn’t pick any winners, but I’m very curious to hear which DJ software everyone here prefers for each type of STEMs separation:
  • DRUMS: Rekordbox
  • DRUMS: Serato
  • DRUMS: djay Pro
  • DRUMS: Virtual DJ
  • DRUMS: Traktor Pro
  • DRUMS: Engine DJ
0 voters
Preferred DJ software for Bass separation:
  • BASS: Rekordbox
  • BASS: Serato
  • BASS: djay Pro
  • BASS: Virtual DJ
  • BASS: Traktor Pro
  • BASS: Engine DJ
0 voters
Preferred DJ software for Other separation:
  • OTHER: Rekordbox
  • OTHER: Serato
  • OTHER: djay Pro
  • OTHER: Virtual DJ
  • OTHER: Traktor Pro
  • OTHER: Engine DJ
0 voters
Preferred DJ software for Vocal separation:
  • VOCALS: Rekordbox
  • VOCALS: Serato
  • VOCALS: djay Pro
  • VOCALS: Virtual DJ
  • VOCALS: Traktor Pro
  • VOCALS: Engine DJ
0 voters
One thing is clear watching this video compared to the 2022 one - STEMS have improved considerably across all DJ apps. Great to see!
I can’t take part in this survey because I don’t own all the relevant software. I only have DJay and Traktor.
For me, more than the quality of the stems, it’s the ability to create them live that’s the deciding factor. Traktor certainly generates high-quality stems (like most programmes these days, including DJay), but they need to be prepared in advance, which leaves very little room for improvisation.
In my case, I mix very long sets, lasting several hours, and I can’t rely on a pre-planned playlist. So there’s a lot of improvisation involved. Since I’ve been mixing with DJay and using stems, my approach to mixing has completely changed; I constantly use stems (along with loops) for my transitions – the potential is endless.
I’ve never been able to use Virtual DJ, but I can see a feature in their stems that I’d be very interested in having in DJay: the ability to isolate the kick. I mix a lot of electronic music, and it would help me even more to be able to isolate the rhythm section and remove the kick whilst leaving the bassline, for example. Great for EDM.
Hi @Chapalo, thanks for the input. In the second half of the video above, Mojaxx does audio comparisons of each software and each STEM part. You don’t need the apps to do your own comparisons - you can simply listen to the differences in his video.
A stem quality survey on the Algoriddim forum and everyone’s voted for djay Pro…
How unexpected :laughing:
You are of course free to create your own survey on the Virtual DJ forum. I mostly thought this would be fun and wanted to share Mojaxx’s video…
I wasn’t being negative - I just found it funny.
For those using djay Pro on Windows though (which limits the quality, where other DJ s/w does not) it’s not as clear cut IMO.
Majority of influences, dj training schools, dj bloggers think also that Djay pro comes out on top. VDJ not far behind though.
Would be great if you could share some specific examples or videos @Dysfunk_DJ
Sure
https://www.reddit.com/r/DJs/comments/1f43ru8/rating_stems/
Been others like Crossfader, Cleveland Terry who have expressed great feedback for Djay Pro stems.
of course I am sure it will change as time goes on. Traktors, VDJ, Nuo Stems, Serato and Djay Pro will all look to improve.
Nice! Thanks for sharing these @Dysfunk_DJ
These are just a few. I think when people check out Djay Pro they do realise just how good it is. Nick Spinelli one of them. He said he would switch from Serato once the Rev 7 was supported. I don’t think he has switched yet but it just shows how good djay pro is.
Thanks again for sharing @Dysfunk_DJ. I’ve seen both of those videos above plus others, but thought it would be better if someone else shared them instead of me :grinning_face:
Personally i have use stems on RB, Serato and Djay Pro
Aside from the audio quality, what makes me pick djay pro as my go to software to DJ is the stems is so light, it doesnt strain the system, my laptop is barely warm
Rekordbox stems is really heavy and slow, like seriously heavy
Fyi i use a Macbook Air, not macbook pro (personal choice, i like to travel lite and save space on my work bag)
Thanks for the feedback @echa0361
Since I usually only need STEMs for the kick, there is no way for me to avoid VDJ, because only VDJ can do that, as far as I know.
