26ms shift issue when converting cues/loops between softwares
Found very interesting article related why the beatgrids and cues/loops might not match …
So, the probelm might not be that our tools are working incorrectly.
When we are using different tools we are editing mp tags resulting incorrect data into them.
=> Tools doesn’t know how to handle the incorrect data.
And the actual root cause might be the encoder sw entering incorrect data to files.
So remember this when moving data using new OneLibrary.
The article talks of 6% of the files beeing offseted by 26 ms.
A terrible quality control :rofl:
10000 files > 600 “not correct” files. its going to be lot of work … and surprises.
And no way to detect which file is badly transfered by the OneLibrary.
i tested it before reading all this, and the first cue of the first track I played in djay was a loop and it was wroooong, hahaha.
hahaha!
I thought i was alone. For years I fought with encoder shifts - they actually worse with MP4’s - i think a much larger % of tracks have shifted cues n loops. Dealing with a shifted cue is easy because sync can take care of it, but a shifted loop can’t be used whatsoever! You have to delete and redo afresh
I handle my track prep in serato (inputting cues and loops), then djay reads those. Most of the time they’re not shifted though when you meet that one track with a shifted cue/loop, it’s so annoying.
  • Device model (all platforms and models):
  • Version of operating system (all platforms and models):
  • Version of djay (5.5):
  • Hardware/controllers used (none):
  • Hardware firmware version (noonne):
Maybe not a bug but a known issue. Im takingg about the 26 ms shift in beatgrids/hotcues that mp3s get when converted from DJay to Rekordbox via One library.
Alot of beatgrids are correct but there are some (uncerttain of how many) that get this shift and therefore, using djay pro ai beatgrids its not very reliable when using on for example CDJS. Until this gets fixed, such as many 3rd party converters have managed to do (DJCU,DJ data converter or Rekordbuddy) its extreamly unrealiable and unsuable dare I say when using sync.
Heres an explanatory article DJ collection converters - DJ Knowledge Base
Lets hope Algoriddim & Alphazeta manage to fix this issue. :slight_smile:
Regards
Jay Dizzle
Hi @Jay_Dizzle, I’ve merged your new topic with this existing discussion. Thanks for sharing. Our team is aware of this.
thanks for quoting my research
the “6% tracks with issues” came from measuring my own collection:
600 out of 10000 files is the “insanity sweetspot”:
  • common enough to be a serious problem;
  • uncommon enough to be a hard to debug pattern
Thanks for sharing @dj_estrela
