I would like to suggest a 3 and 4 deck stack view (similar to Serato) or even a condensed deck view where a portion of the screen can display the library at all times. Im currently using a Reloop Flux and there is no easy way of using the 3rd deck in the hardware mode without switching to 4 decks and having no library at all.
Perhaps even the condensed decks that Traktor use so you can see basic info like the overview waveform, time remaining, loop length etc, with a space for some cue pads underneath then the bottom 1/3 of the screen for the library.
Ive also seen in the Engine where there is a ‘performance’ mode with the library down the centre portion of the screen and decks either side of it, so you can still scroll through and the deck is taking up the full screen from top to bottom.
Yeah sort of, but I’d rather see all 3 decks at once. The suggestion there is to have a tab on the deck to switch between deck 1 and 3 (another Serato feature).
Hi @Slak_Jaw this is an example of the 3 deck stack in Serato, and also demonstrates what a compact deck could look like. Perhaps there could be room to the right of the deck for some on screen cue pads (thinking touch screen) with the rest for the waveform.
Thanks for the screenshot @STU-C . I’ve passed this onto the devs for consideration. In the meantime, please use the blue Vote button so we can gauge user demand for this feature. Thanks!
