Not sure if it has been mentioned before but as much as I love 4 deck layout I believe a 3 deck layout with a little more control (e.g cue button, neural mix button) would be better for touch operation. Having to goto different pages for cue while adjusting pitch is quite difficult because it changes all decks to display the cues and etc. pages, not just the deck in use. Or if some how could squeeze a cue button and make all decks effect/cue pages be independent for 4 page layout could be more effective as well? Would love some feedback if others think this would be helpful as well. Cheers ![]()
I agree, i rarely need 4, but 3 would be usefull.
Thanks for the suggestion @djmondop! I’ve shared this with the dev team for consideration.
If it were possible to put the option of three decks because in my situation I use deck 1 and 2 to mix, but I use a third to create scratch with my deck 3, but since I have to use the option of 4 decks the effects look very small and cues, if they managed to put the option of 3 covers everything would look bigger.
I like this idea as well. I often use 3 decks, but rarely 4 so the extra space for FX, Hot Cues, Loops, Library, etc. would be great.
Just to add to this, it’d be really handy in 4 deck mode to “hide” decks to create a 2 or 3 deck setup.
Using Djay Pro on an iPhone 12, 4 deck mode is perfectly serviceable but I can’t help thinking that it’d be even better if I could use the 4 deck mode UI for a 2 deck or 3 deck set. The vertical waveforms are much easier to use IMO, and I love having more screen real estate for the FX pad and neural mix faders ![]()
Thanks for the additional feedback @Algy_Taylor. I’ve passed this onto the devs.
this is a nice idea !
Please allow a 3-deck only mode. 4 decks takes too much real estate. It would be super helpful to just have the option and be able to take full advantage of the software.
Hi @Jason_Jaso, please use search before creating new topics. I have merged your new topic with this existing one. You can cast your vote for this suggestion at the top left of this page. Thanks!
- When two decks are matched together one for beat (Master), the other for song, it is always difficult to load song and arrange before it is played and everyone listening to the song will know that you’re searching for music. OR you play all the songs singly and using crosfader to change song. My suggestion is I wish djay could have up to 3 decks for the ease of changing of song and will bring about more efficient DJing.
- Search button failed sometimes and whenever this happens I have to restart the app before I can solve the issue.
- Scroll bar in the local music library.
Thanks for this great and wonderful app.
From Android user.
Hi @Saviour_Peter, thanks for the 3 Deck Mode and scroll bar suggestion for Android. I will share this with the dev team for consideration. In the meantime, please use the blue Vote button so we can gauge user demand for this.
Regarding #2, can you please try to capture a short screen recording of this and share it here? Thanks!
Would it be possible to have 3 deck mode. Whilst 4 decks is great, when using an ipad, it feels a bit squashed in. I very rarely use 4 decks but often need a third deck. If it was just 3 decks then you would have more space for a better layout
Thanks for the suggestion @David_Bielby. I’ve merged this with an existing suggestions for 3 Deck Mode on Android. Please re-vote above. Thanks!
This sound good, so it would be 4 deck mode with the option to hide any of the decks. If that were possible, you would always use 4 deck mode but with 3 & 4 hidden until you need them.
Thought of the day, given the collaboration with AlphaTheta of Djay Pro and the recent 3-channel V5 mixer, do you think they will implement the 3-deck version? ![]()
I really hope so because I would also benefit from having only 3 decks instead of 4. ![]()
There’s an existing thread about 3 decks somewhere I think.
Hi @Scoop, I’ve merged your new topic with this existing one as they’re closely related. Please Vote above. Thanks!
