- Device model (e.g. 2020 iPad Air 4th Gen): PC, AMD Ryzen 3700X
- Version of operating system (e.g. macOS 14.4.1): Windows 10
- Version of djay (e.g. 5.1.2): 5.1.8217.0
- Hardware/controllers used (e.g. Reloop Mixon 8 Pro): Lynx Studio E44 PCIe soundcard
Summary of the issue:
The Lynx E44 ASIO drivers support buffer sizes down to 32 samples, however djay only lists/shows buffer sizes down to 64 frames/samples. Even after selecting 32 samples in Lynx’s ASIO Control Panel, djay reverts it back to 64 samples. Here’s an image of djay Pro and Lynx ASIO Control Panel:
For comparison, my Rane SL2 supports a 48 frame/sample buffer and djay correctly reports and uses 48 samples with no issues, so buffer sizes less than 64 frames/samples appear to be supported by djay.
How to reproduce the issue:
Configure the ASIO audio buffer size for a Lynx Studio audio device.
