since i did the update to 4.1 djay doesn’t find my reloop digital jockey 2 master edition as a output anymore. does anybody has the same problem and knows a solution?
Hi Tobias,
This is a known issue. It seems as if some audio devices are not compatible with sandboxed applications such as djay (starting with 4.1). Sandboxing is a (security) requirement for applications in the App Store.
Please kindly contact Reloop support to check whether there are any driver updates that support sandboxing.
