I’m thinking of getting an Allen & Heath Xone:K2 controller and am wondering if it might be possible, now or someday, to use a 4 band EQ (“equaliser/equalizer” for search) when mixing in Internal mode. I’d like to map the outer two controller strips/channels on the K2 thus: knobs, hi/mid-hi/mid-low; and low-low on the fader, top position being equivalent to centre on an EQ knob. I don’t know what crossover frequencies these controls should be set to but the obvious inspiration to take would be A&H’s Xone mixers that have 4 band EQ, if you were to be interested in this. I’m interested in using this setup with my Mac and maybe my iPhone.
Thanks for the suggestion @lief. Currently djay only supports 3 Band EQs. I have forwarded this to the dev team for consideration. In the meantime, please use the blue Vote button at the top left of this page so we can gauge user demand for this feature. Thanks!
Please note that djay does support 4 Channel Neural Mix Volumes for Drums, Bass, Harmonics and Vocals so perhaps this might work for you in the meantime.
