I have the PRO version, but I don’t see the option to select 4 decks. My phone model is Redmi Note 12 Pro 5G. Thank you.
Hi @Federico, welcome to the Community! Please note that 4 Deck Mode is not currently available on Android. To access this you will need an iOS, macOS or Windows device. I hope that helps!
Bonjour @Federico,
Est-ce que la fonctionnalité 4 deck sur Android est en cours de développement ou n’ est ce pas une priorité ?
Merci par avance de votre retour
Hello @Federico,
Is the 4-deck feature on Android currently under development, or is it not a priority?
Thank you in advance for your feedback.
Hi @Sebastien_Soyeux, I’ve changed this topic from a Question to a Suggestion so that you and other users can up Vote it and we can gauge user demand for this feature. Thanks!
