4 Deck mode - which channel is playing?
Latest Versionof DjayPro and iPad
Your question:
I am using a DDJ FLX10 4 Channel DJ controller.
On the controller, I can toggle between 3/1 and 4/2 but neither on the controller nor in the software in 4 deck mode I can’t find an indicator which channel is acturally active.
How can I tell which channel is acutally going to play befoce I hit the Play button?
That information is on the jog display. You might have to switch display modes. On it you can view artwork, waveforms, etc…
Thanks @DJ_A_Diffrance, that’s right! Did not look at the jog wheel screens as they are unfortunately not supported by Djaypro but when toggling channels with the hardware button on the DDJ FLX10 at least the channel is indicated in the jog wheel screen…
