4Decks Hardware Mode screen on iPad
Can we please have a 4decks “Hardware Mode” screen, that is optimized for 4 channel controllers?
At a glance, and in the upper section, I would need:
  1. time remaining & time elapsed
  2. BPM & Tempo values
  3. Sync & Key Lock status
  4. Loop & Beat Jump sizes
Most of the time, I would be looking at the FX tabs in the “Tools” pannel on screen, as I’m using the FX assignment per NM channel, and seeing the just the FX1 panel, as in 2Deck HW mode is not as essential for me. the 4 above are, though.
Being able to enable the “Mini Looper” panel in place of “Tools” would be very beneficial too. I was thinking that we may do fine without the “Mixer Panel” of the current 4 channels mode, but thinking of it, there are people mixing on 2channel controllers with 4 decks, so perhaps the Mixer Panel will get some good use for some DJs and should remain present in 4 decks HW mode.
Thanks for the suggestion @Kaloyan. This has been suggested elsewhere, but I couldn’t find the topic. The good news is that you won’t need to wait long on this one :wink:
Cool, thanks!
looking forward to use the HW optimized 4 decks layout!
I will also wait to check and see what MIDI actions will be made available for controlling the layout before submitting new enhancements requests.
You’re welcome @Kaloyan. Sounds good.
(post deleted by author)
