Hi
So when opening certain music folders from the finder window node or adding those folders then selecting them DJ Pro crashes. Only happens on certain folders though. the folders contain only mp3, or wav audio files. thinking it could be a corrupt file , though i highly doubt this i went through song by song of the same folder on other dj software and they played or loaded without a htch, i then scanned the said folder and no issues reported. again tried to select the folder within DJ Pro and once selected again the programme crashes. folder has roughly 200 songs in it. Using the latest 5.0.1 update on macbook pro 16gb, osx Catalina 10.15.7
Could send a crash log if needed.
Not sure if there is an easier way to send a crash log then to copy paste it though.
