500 Errors When Loading Spotify Playlists?
When I try and access my spotify playlists in djay2, my available playlists appear briefly, then I get “500 error: resource not available - Try Again” (or words to that effect) … repreatedly hitting the the ‘Try Again’ button has no effect … other spotify features seem to work ok (ie: browse/genre lists/match etc)…
If I select a playlist before I get the error I can access it and play the content, but this eventually fails.
I’m running the latest version of the software, I’ve never seen this error in previous versions.
Please advise!
Please log out of Spotify and try to login again.
If the problem still persists, please reach out to our support team with informations about your device and the operating system that’s running on your device at: support(at)algoriddim.com
Best Regards,
Lukas
I’ve tried to that several times but it hasn’t made any difference.
iPad is model A1396 running iOS 9.1 Spotify version 4.3.0.1426 and djay version 2.7.11
The wording of the error when I try and load my Spotify playlists in djay is “Request failed:internal server error (500)”
Please advise
