502 Bad gateway spotify with mac
I am trying to connect my spotify with day pro for mac, it was working fine before but now when I try sign in I get a white screen saying “502 Bad gateway”. Spotify is working fine through spotify app also on mac.
This could be due to a temporary server problem. Please try if you can login here:
http://lab.possan.se/thirtify/#/
I have exactly same problem for the second time in last week and it’s pretty frustrating…
I’m also having this problem. I signed into the server above and it looked a bit like Spotify, without any of the music or pictures when I clicked on anything. I’m just going to assume the server is down atm.
Hi Matt,
are you still receiving the 502 bad gateway error?
Hi Matt Kriese,
is the problem persisting?
We improved our Spotify support with the new update of djay Pro 1.3.
Check it out.
Hi guys,
can you share screenshots of the Error with us?
Also can you give us further information on the exact djay version you are using and macOS?
Having this problem with accessing music on spotify
I am having the same problem with Djay Pro 2. Extremely frustrating
